Andrea_Arquint
Jun 21, 2013how to remove a specific string from a variable
I would like to remove a specific string from a variable that contains differnet strings.
How can such thing be done?
thx
bb
- nitass
Employee
can you give some example? - Andrea_Arquint
Posted By nitass on 06/21/2013 06:29 AM
for example:variable TEST contains:
a=test_a&b=test_b&c=test_c&
1. case: I would like to filter b=test_b& and remove it
2. case: if b=test_b& is removed I want to add another one d=test_d&
no matter in which order they occur.
