weikang_Hu_9799's avatar
weikang_Hu_9799
Feb 13, 2007
How to prevent hot links/bandwidth stealing by irule
Hello :
I am looking for a solution to prevent from the hot linking /bandwidth stealing .
I belive this can be done by irule . Is there someone can input a basic idea /logic except using referer header ?
  • Richard__Harlan's avatar
    Richard__Harlan
    Historic F5 Account
    Colin, iRule for stopping phishing for the most part lays out what you need. http://devcentral.f5.com/Default.aspx?tabid=28&forumid=5&view=post&postid=12618
    If there is more then one domain that need to link to your domain then create a match class, it will make it easer to add and remove domains. From there you can just drop or reject the request or you can change the picture to something else. But if bandwidth is something you are worried about I would use the reject or drop. Note with the Drop the BigIP does not send a rest packet back to the client so the client will just wait till it timeout from the request.
