SW_159148's avatar
SW_159148
Aug 08, 2014
How to mirror SNAT when using an iRUle with "snat automap"
I have configured the following iRule which will SNAT only when the source and destination subnet are the same. It works fine, but I can't figure out how to enable connection mirroring on a SNAT when it is called out in an iRule.
when LB_SELECTED { if {[IP::addr "[IP::client_addr]/24" equals "[LB::server addr]/24"]} { snat automap }}
Thanks.
  • Hi SW,
    Are you talking about connection mirroring on the VIP and having it on/off based on an iRule?
  • but I can't figure out how to enable connection mirroring on a SNAT when it is called out in an iRule.
    i understand you just need to enable connection mirroring for virtual server (since snat is applied to traffic for virtual server).
    connection mirroring for snat in sol13478 could be applied to snat list configuration.
    sol13478: Overview of connection and persistence mirroring (11.x)
    http://support.f5.com/kb/en-us/solutions/public/13000/400/sol13478.html
