haque_119100's avatar
haque_119100
13 years ago
How to migrate from Alteon load Balancer to LTM?
We have a pair of HA Nortel Alteon 2424 Load balancers. We recently bought LTM 8900.
Is there any conversion script available to translate the existing Alteon rules to LTM rules and policies?
I found a reference script for Radware to LTM conversion.
Can anybody help? Can anybody has similar experience?
Please share.
Thanks in advance
  • Hey Haque. I see you also posted a question on the Radware script page. I can't directly help you I'm afraid but might I suggest getting in touch with F5 support or your F5 representative? I would have thought whoever sold you the 8900's would be more than willing to help out too.
  • Can you please send me the location of the script for Alteon to LTM Conversion
  • Hi, you can find informations on this page : https://devcentral.f5.com/articles/big-ip-configuration-conversion-scripts.Uv3V9XlSlgp
    If this script does not work for you, let me know and I will provide you with mine. But it should be the same.
  • Hi
    The radware conversion script doesnt work, it pushes out only the Irule's, Standard Re-direct rules, persistance profile, protocol profile
    None of the Pools, Nodes, and Virtual Servers are exported
    Can you assist me further?
    Zak
