Forrest-Z
Cirrus
Mar 13, 2024How to lift the connection limit for a given IP address ?
help me
when CLIENT_ACCEPTED {
if {[IP::addr [IP::client_addr] equals 10.3.125.142 ] } {
TCP::limxmit disable
log local0. "#######limit disable action "
This script doesn't work, is there another way?
https://clouddocs.f5.com/api/irules/TCP__limxmit.html isnt the connection limit.
This one is probably what you are looking for: https://clouddocs.f5.com/api/irules/LB__connlimit.html
- Forrest-Z
Cirrus
extremely grateful
