how to install iControl SDK for python
hi,dear friends,how to install iControl SDK for python,give me the detail,i use the userguide can't install https://github.com/F5Networks/f5-common-python,need some conditinos before install??
Per that packages documentation, I believe it can be installed with the python package manager (pip).
$ pip install f5-sdk- lhh_239102
Traceback (most recent call last): File "/usr/lib/python2.7/site-packages/pip/basecommand.py", line 223, in main status = self.run(options, args) File "/usr/lib/python2.7/site-packages/pip/commands/install.py", line 290, in run requirement_set.prepare_files(finder) File "/usr/lib/python2.7/site-packages/pip/req/req_set.py", line 334, in prepare_files functools.partial(self._prepare_file, finder)) File "/usr/lib/python2.7/site-packages/pip/req/req_set.py", line 321, in _walk_req_to_install more_reqs = handler(req_to_install) File "/usr/lib/python2.7/site-packages/pip/req/req_set.py", line 491, in _prepare_file session=self.session) File "/usr/lib/python2.7/site-packages/pip/download.py", line 825, in unpack_url session, File "/usr/lib/python2.7/site-packages/pip/download.py", line 673, in unpack_http_url from_path, content_type = _download_http_url(link, session, temp_dir) File "/usr/lib/python2.7/site-packages/pip/download.py", line 886, in _download_http_url _download_url(resp, link, content_file) File "/usr/lib/python2.7/site-packages/pip/download.py", line 621, in _download_url for chunk in progress_indicator(resp_read(4096), 4096): File "/usr/lib/python2.7/site-packages/pip/utils/ui.py", line 133, in iter for x in it: File "/usr/lib/python2.7/site-packages/pip/download.py", line 586, in resp_read decode_content=False): File "/usr/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/response.py", line 307, in stream data = self.read(amt=amt, decode_content=decode_content) File "/usr/lib/python2.7/site-packages/pip/_vendor/requests/packages/urllib3/response.py", line 267, in read raise ReadTimeoutError(self._pool, None, 'Read timed out.') ReadTimeoutError: HTTPSConnectionPool(host='pypi.python.org', port=443): Read timed out.
