Robert_Reznicek's avatar
Robert_Reznicek
May 03, 2010
How to initialize global variable on standby unit
Hi there,
I have some global variable initialized within a RULE_INIT event. This variable is visible on active unit, however when I make a standby unit active, this variable is not visible. Is it possible to propagate this variable to the standby unit somehow please?
Thanks a lot!
  • variables are not synced to standby systems. However, if you use the session command (or table if on v10.1+) that data is mirrored, and so you should be set.
  • hoolio's avatar
    hoolio
    I tested using the session table for a globally accessible variable in v10.0.x. But I didn't think to test this for mirroring. Maybe it would work for you?
    http://devcentral.f5.com/wiki/default.aspx/iRules/CMP_v10_compatible_counters_using_the_session_table.html
    If you try it, could you reply back?
    Thanks, Aaron
