Grain_131632's avatar
Grain_131632
May 05, 2014
HOW TO GET SYSTEM CPU Usage?
hi,friends: i have a question..HOW TO GET SYSTEM CPU Usage by icontrols?
What method should be invoked to get CPU utilization on the BigIP? like this...
  • Did you try to get with method "get_all_cpu_usage_extended_information" in namespace "System.SystemInfo"? I think is there.
  • dont believe that is possible in the GUI
    you can you top in the CLI to check processes, but not sure if icontrol jumps out then.
  • I'd also like to know if it is possible to get CPU history data via iControl so that I can plot it myself. Or is there a way to get the complete graph via iControl?
