How to do tcpdump for APM AAA authentication?
Hi, i need some advice.
I've setup an APM for the OTP authentication with Radius server. From the APM logs, i do received the Access-Reject packet from Radius module.
/Common/DEV:Common:b1d4b3bc: RADIUS module: authentication with 'ACB123' failed: Access-Reject packet from host 127.7.0.3:1812 (3)
But from my counterpart, the Radius team said from their packet trace they don't received any Access-Request packet from F5.
How can i apply tcpdump or anyway to find out which host is replying the Access-Reject packet from Radius? Because APM log above didn't tell the actual IP where i want to prove to the Radius team the Access-Reject packet is coming from their end.
Pls share me the commands, thanks.
Something like this:
tcpdump -enni 0.0:nnn udp port 1812 or udp port 1645- David_Gill
Cirrus
Don't forget to ensure you have the proper routing in place to reach your Radius server.
