How to do a NOT URI with switch -glob
There is a VIP with an irule on it using the switch -glob format. Something like
switch [HTTP::uri] {
"/foo/* -
"/bar/* { pool blah
} default { pool default
Now the application team that own the VIP would like to change that to something like
**NOT** "/foo/* -
"/bar/* { pool blah
So that if the conditions do not match either /foo/ or /bar/, than redirect to pool blah. Not sure what the right syntax for that would be.
- VernonWells
Employee
Without resorting to regular expression matching (which should be avoided), I believe there is no way to do the kind of negation that you are describing with a
. This leaves you with two options:switchswitch [HTTP::uri] { "/bar/*" { pool blah } default { if { !([HTTP::uri] starts_with "/foo/") } { pool blah } else { pool default } } }or
if { [HTTP::uri] starts_with "/bar/" || !([HTTP::uri] starts_with "/foo/") } { pool blah }then just set the VS default pool to "default". Unhappily, in this, you can't avoid the double-evaluation in the worst case.
