venu_96110's avatar
venu_96110
Nov 21, 2008
How to divide traffic between nodes along with persistence in place
Hello,
My requirement is to divide the traffic between the two nodes that i have with 75% to one node and 25% to another node. Also once the users lands on one particular node should get passed to the same without fail as each node will have slight changes in product implementation. I have come up with the following solution. Please review and let me know if there are any better approaches or can i do use the below implementation i have come up with.
node 192.168.1.151 {
screen test01
ratio 3
node 192.168.1.152 {
screen test02
pool test_http_pool {
lb method member ratio
monitor all http
member 192.168.1.151:http ratio 3
member 192.168.1.152:http
pool test_https_pool {
monitor all https
member 192.168.1.151:https ratio 3
member 192.168.1.152:https
virtual test_http_virtual {
destination 111.222.333.444:http
ip protocol tcp
profile http tcp
persist source_addr
pool test_http_pool
virtual test_https_virtual {
destination 111.222.333.444:https
ip protocol tcp
persist source_addr
profile http tcp test_ssl_profile
pool test_http_pool
Thanks,
Venu
  • hoolio's avatar
    hoolio
    Hi Venu,
    That looks good. You shouldn't need the https pool if you're decrypting (and not re-encrypting) the client traffic. You could also use cookie insert persistence for both VIPs as you're using the same pool for both VIPs.
    Aaron
