rgordon_01's avatar
rgordon_01
Sep 21, 2017
How to determine if LTM 1600 can handle decrypting and encrypting for exchange2016
Is there any documentation that will tell if our LTM 1600 can handle ssl offloading for our exchange environment. We have about 7400 clients that will be connecting to the VIP. the VIP will decrypt then re-encrypt before sending to back end servers.
  • The authoritative answer to this would be to talk to your account team. They can look at your actual traffic (7400 clients could be 74000 connections, potentially) and the ciphers you are using and determine whether this will be a problem for you.
    This doesn't sound like a tremendous load, but if you are using a cipher that is not hardware accelerated or are using an exceptionally large key you could run into problems. Also be aware that the 1600 is end of sale and will be end of Software Development next month.
  • Hi,
    I have a customer with 20000 users connecting to Exchange 2013 / sharepoint 2013 / Office Web App / Skype on 2 Datacenters with GTM, LTM and APM
    the max connection on each DC is:
    (tmos) show sys performance connections
    Sys::Performance Connections
    Active Connections           Current  Average  Max(since 09/22/17 13:27:10)
    Connections                     8.8K     9.5K                         10.2K
    Total New Connections(/sec)  Current  Average  Max(since 09/22/17 13:27:10)
    Client Connections                86       93                           109
    Server Connections                74       79                            95
    HTTP Requests(/sec)          Current  Average  Max(since 09/22/17 13:27:10)
    HTTP Requests                    167      237                           335
    average SSL TPS is:
    (tmos) show sys performance throughput historical
    Sys::Performance Throughput
    Throughput(bits)(bits/sec)     Current  3 hrs  24 hrs  7 days  30 days
    In                               75.6M  53.1M   23.5M   21.9M    22.1M
    Out                              77.3M  54.9M   24.0M   22.5M    22.7M
    SSL Transactions               Current  3 hrs  24 hrs  7 days  30 days
    SSL TPS                             34     38      19      19       32
    Throughput(packets)(pkts/sec)  Current  3 hrs  24 hrs  7 days  30 days
    In                               11.0K   8.3K    3.8K    3.7K     3.8K
    Out                              12.9K   9.8K    4.4K    4.3K     4.4K
    the max of last hours is :
    Throughput(bits)(bits/sec)     Current  Average  Max(since 09/22/17 13:24:59)
    In                               67.5M    53.7M                        124.3M
    Out                              69.4M    55.5M                        125.8M
    SSL Transactions               Current  Average  Max(since 09/22/17 13:24:59)
    SSL TPS                             35       38                            52
    Throughput(packets)(pkts/sec)  Current  Average  Max(since 09/22/17 13:24:59)
    In                                9.3K     8.4K                         16.7K
    Out                              11.2K     9.9K                         19.5K
