alok_sinha_1336's avatar
alok_sinha_1336
Jan 22, 2014
How to create bootable thumbdrive for 3900 LTM
Hello guys, we have a F5 device failure so we've got a new RMA'd box available now. Please guide me with the procedure to create bootable thumbdrive from other working F5 device placed at same location and how to proceed with installation.
thanks in advance :-)
  • Thanks for your help :-) I have gone through it but this doc mainly shows command to create bootalbe USB via Linux workstation. but I'm using another F5 device to create bootable USB so what are the checks and commands for the same. Pls guide me with commands. thanks!
  • this doc mainly shows command to create bootalbe USB via Linux workstation.
    it is the same command you run on bigip device.
    1. Log in to the Linux workstation or the BIG-IP system as root.
  • Okay..let me do it as suggested and will get back to you if I'll stuck anywhere. Thank you very much!!
  • hi
    They could help me? I followed the steps in the link where it is mentioned as creating a bootalbe usb does not work, chances are I'm doing something wrong. what I am doing is this.
    • The first thing I did was put on the USB the iso image
    • Mount the usb in the /mnt/cd
    • run the command mount -o loop BigIP-10.1.0.5399.0.iso /mnt/cd
    • In the route cd /mnt/cd I run the command ./mkdisk but shows me that it does not, Do you know that this error is due?
