philippe_loeb_7's avatar
philippe_loeb_7
Jan 31, 2014
How to choose an output interface following the address source by using irules
I have two provider Internet connected to F5. I d like to choose one output interface following the source IP local and in case of provider failure, redirect the traffic on the other output interface
Can I use irules
  • Richard__Harlan's avatar
    Richard__Harlan
    Historic F5 Account
    The easy way to do this would be to source the connection from a IP address bound to a VLAN on the interface you want the traffic to flow out. You can do this with the SNAT command.
    snat  [] | none | automap
    If the connection fails you can used the LD_FAILED event to reselect the link and source the connection from another IP address to use the other connection.
  • I have two provider Internet connected to F5. I d like to choose one output interface following the source IP local and in case of provider failure, redirect the traffic on the other output interface
    Can I use irules
    Yes you can.
    when CLIENT_ACCEPTED {
        if { [active_members pool_link1] >= 1 } {
            pool pool_link1
        else {
            pool pool_link2
