How to check if load balancing method(ratio) on GTM is actually happening
Hello, We are load-balancing 2 LTM VIPs on GTM with ratio 1:1, but looks like one of the VIP is taking lesser traffic. Is there anyway to check: 1.) The ratio is actually working 2.) If the load balancing method is not working, can we pinpoint the issue?
Does the GTM send more requests to the VIP that is working fine even though the ratio is 1:1?
Note: we experienced some latency issues with the servers a few days back.
- Root44
Altostratus
Have you already set up everything?? If yes then try to go in pool statistics.
- Karthik90_14146
Yes, its already been setup and in the stats i can see that one VIP is taking more traffic, but I'm not able to identify the reason.
