kris_52344
Mar 20, 2009how to change firepass box interface IP`s in cluster mode
Hello,
I am having two SSl-VPN(1200) box in cluster mode under producion.
& have plan to change the Interface IP`s,VIP & default gateway.
after reading theory i decide to do this as follows:
1] remove cluster
2] delete existing inteface IP then add new IP
[can i able to access the firepass console
after clicking Update?]
3] change default Gateway
4] change cluster & failover configuration.
5] Finalise changes & reboot.
or is there any other way to do this activity in less downtime?
Please Guide.
Thanks in advance.
- mal_57091
Hi There,
Umm...you must been failover pair not cluster. FirePass 1200 does not support clustering (though FirePass 4100/4300 does). So assuming you mean failover pair what you have seems okay. The only thing to be very careful of is that you do not re-join the slave to the primary unit before all config changes are made otherwise you risk having the slave unit overwrite the master with old/incomplete config.
Good luck!
Cheers,
Mal - kris_52344
Thanks Mal..
I am having two SSl-VPN(1200) box in failover mode under producion.
what is Best Practice for the same..
can anybody help me out, as i m new in this vpn technology.
