How to change datagroup value by using pyhthon script (f5-sdk 1.6.0)
My aim is to change data group value of /Common/zol from 'on' to 'off' by using python script. I am unable to update/set values. Please help.
datagroups in /Common partition aol images private_net zol
My sample code (basic) and output is shown below:
Sample script
! datagroup.py import json from import ManagementRoot import requests from requests.packages.urllib3.exceptions import InsecureRequestWarning requests.packages.urllib3.disable_warnings(InsecureRequestWarning)
! Connect to the BIG-IP mgmt = ManagementRoot("192.168.1.1", "admin", "admin1")
! Read data group value (Local Traffic -> iRules -> Data Group List) datagroups = mgmt.tm.ltm.data_group.get_collection() print (datagroups) print ("\n") ! dg = mgmt.tm.ltm.data_group.internals.get_collection() print (dg) print ("\n")
for dg1 in dg: print (dg1.name) print (dg1.partition) print (dg1.records) print ("\n") dg1.records = "[{'name': 'off'}]" print (dg1.records) print ("\n") dg[3].update()
Output
E:\LAB\python> E:\LAB\python>python datagroup.py [{'reference': {'link': ' 1.5.3'}}, {'reference': {'link': ' nal?ver=11.5.3'}}]
[< object at 0x028ECD90>, < ta_group.Internal object at 0x028ECF90>, < ob ject at 0x028ECF10>, < object at 0x029120F0>]
aol Common [{'name': '64.12.96.0/19'}, {'name': '195.93.16.0/20'}, {'name': '195.93.48.0/22 '}, {'name': '195.93.64.0/19'}, {'name': '195.93.96.0/19'}, {'name': '198.81.0.0 /22'}, {'name': '198.81.8.0/23'}, {'name': '198.81.16.0/20'}, {'name': '202.67.6 5.128/25'}, {'name': '205.188.112.0/20'}, {'name': '205.188.146.144/30'}, {'name ': '205.188.192.0/20'}, {'name': '205.188.208.0/23'}, {'name': '207.200.112.0/21 '}]
images Common [{'name': '.bmp'}, {'name': '.gif'}, {'name': '.jpg'}]
private_net Common [{'name': '10.0.0.0/8'}, {'name': '172.16.0.0/12'}, {'name': '192.168.0.0/16'}]
zol Common [{'name': 'on'}]
[{'name': 'off'}]
Traceback (most recent call last): File "datagroup.py", line 28, in dg[3].update() File "C:\Program Files (x86)\Python35-32\lib\site-packages\f5\bigip\tm\ltm\dat a_group.py", line 69, in update return self._update(**kwargs) File "C:\Program Files (x86)\Python35-32\lib\site-packages\f5\bigip\resource.p y", line 511, in _update response = session.put(update_uri, json=data_dict, **requests_params) File "C:\Program Files (x86)\Python35-32\lib\site-packages\icontrol\session.py ", line 241, in wrapper raise iControlUnexpectedHTTPError(error_message, response=response) icontrol.exceptions.iControlUnexpectedHTTPError: 400 Unexpected Error: Bad Reque st for uri: https://192.168.100.1:443/mgmt/tm/ltm/data-group/internal/~Common~zo l/ Text: '{"code":400,"message":"the \"create\" command does not accept wildcard configuration identifiers","errorStack":[]}'
E:\LAB\python>
- Dario_Garrido
Noctilucent
