anson_5390's avatar
anson_5390
Nov 12, 2007
How to add Wide IP?
I can use Link Configuration->Inbound LB->Add to add a Wide IP and it work perfect, but i want to use iControl API to do this.
I has using add_pool_virtual_server,add_wideip,add_pool,but nothing to happen..
Could anybody tell me how to work it?
  • I find parameter is error, the add_pool's type must set LB_RES_A, can't set LB_RES_CNAME.
    But what the mean of LB_RES_A and LB_RES_CNAME?
    Vector params = new Vector();
    params.addElement(new Parameter("wideip_name", String.class, strWideIP, null));
    params.addElement(new Parameter("pool_name", String.class, strPoolName, null));
    params.addElement(new Parameter("type", Integer.class, "0", null));
    executeWideip("add_pool", params);
