Joo_48490
Jun 28, 2010How to add my css, and images in sandbox?
Hello all,
I am having some issues with my firepass login page customisation.
I have located my css files, and images files in sandbox, but they are not accesible.
So I have located them externally. However, IE displays security warning message. the reason is becasue my index.htm is trying to access external css and images files.
Can you please help me how to locate my css and image files in sandbox and make them accessible?
Cheers,
Joo
- Don_Ryles_52501
Joo,
Welcome to the devcentral forum.
I'm not quite sure what you mean that they inaccessible and if it's a browser warning have you tried putting the URL for your FirePass access in the browsers trusted zones?
If you are using multiple resource groups then in the sandbox you would normally create a folder called the same name as the resource group which the users are gaining access to. So if you have 2 different sets of users who access resource groups called public and employees then you would have 2 folders with those names each containing their own customisation files. Have a look at the inbuilt help file under Device management / customisation if you haven't already.
Kevin S. - Joo_48490
Hello Kevin,
Thank you for your reply.
I have resolved the problem.
In my css and index.htm, if there are any file references, then i have to do somehting like this. /sandbox/css/style.css OR /sandbox/images/image1.jpg
Previously, I didn't specify /sandbox/, that's why any custom files(css, images, and js) were inaccessible.
