How many ways to rewrite http request and response for hostname, port and URI rewrite
Hello Experts
I need to mask the URL between virtual server on f5 and backend servers. The URL on backend server is http://server1xls.abc.com:8040/OA_HTML/AppsLogin and the URI on F5 should be http://extranetportal. It means I need to mask the hostname, port and URL on F5.
I searched on the forum and this is confusing. Some suggested:
1- Use stream profile in virtual server configuration 2- Use stream IRULE 3- Use Redirect Rewrite in http profile
I would highly appreciate, if somebody give me the solution for this scenario and what is the difference between above solutions
Regards,
GR
- The_Bhattman
The Stream profile is used to re-write Links in a webpage. For example if you masked the backend URL from the client - You might have links that point to backend URL
The good news is that the good folks at F5 had written something to around it
Here is a link that may help
https://devcentral.f5.com/wiki/iRules.ProxyPassV10.ashx
Let us know if this works?
-=Bhattman=-
- ghost-rider_124
Hi The Bhattman
Thanks for reply. This IRULE seems horrible :) but again the same question the below three methods would be used in which condition for my scenario described earlier.
A)- Use stream profile in virtual server configuration B- Use stream IRULE C- Use Redirect Rewrite in http profile
- The_Bhattman
Hi Ghost-rider,
Yes the iRule looks very complicated, but it does work for many people. In your case it could be overkill.
So with the streams are tyring to re-write links on a webpage or hide them from the URL on the internet browser?
-=Bhattman=-
- John_Antony_162
it's been a while someone answered this. But I had a similar situation and below iRule worked great
when RULE_INIT { Set the hostname that the client makes request to (do not include protocol) set ::external_hostname "external.com" Set the hostname that the BIG-IP will rewrite requests to set ::internal_hostname "server1.local.intra:8445" Log debug messages to /var/log/ltm? 1=yes, 0=no. set ::proxy_site_debug 0 } when HTTP_REQUEST { if {$::proxy_site_debug}{log local0. "Received request from [IP::client_addr] -> [HTTP::host][HTTP::uri]"} if {$::proxy_site_debug}{log local0. "Rewriting [IP::client_addr]'s Host header to $::internal_hostname"} Rewrite the Host header HTTP::header replace "Host" $::internal_hostname } when HTTP_RESPONSE { Check if the status indicates a redirect if {[HTTP::is_redirect]} { if {$::proxy_site_debug}{log local0. "Rewriting [IP::client_addr]'s redirect"} Rewrite the Location header replacing the internal hostname with the external hostname HTTP::header replace Location [string map -nocase {$::internal_hostname $::external_hostname} [HTTP::header Location]] } }
