Gregory_Gerard_
Jul 08, 2008How long does it take to establish an HTTP connection?
I'm trying to get worst case information for how long it takes for an LTM 1500 to bring up a brand spanking new TCP connection to handle an HTTP request from the outside world.
Is there a monitor I can look at to quickly find out how much time is spent bringing up new TCP connections?
If I can't find the statistic, could someone venture a guess for what it *should* be for a switch 1gb Ethernet with no routing between LTM and pool members? A ballpark in milliseconds would be great.
thanks!
- JRahm
Admin
Are you asking about the Client->LTM connection, the LTM->Server connection, or both connections? If Client->LTM, that depends on latency (server side too if not on the LAN). I've personally never seen the LTM->Server handshake take longer than 1 millisecond on a directlly connected lan. - Gregory_Gerard_
Both would be good numbers to know. It doesn't seem like it should be much at all.
Along a similar vein, is there a metric for tracking HTTP connection reuse? - Deb_Allen_18Historic F5 AccountI concur with citizen_elah's observation, sub-millisecond for local conns.
You can find OneConnect stats in the MIB. For the default profile named "oneconnect", the "ReUses "OID is:
Full OID:F5-BIGIP-LOCAL-MIB::ltmConnPoolProfileStatReuses."oneconnect".iso.org.dod.internet.private.enterprises.f5.bigipTrafficMgmt.bigipLocalTM.ltmProfiles.ltmConnPool.ltmConnPoolProfileStat.ltmConnPoolProfileStatTable.ltmConnPoolProfileStatEntry.ltmConnPoolProfileStatReuses."oneconnect"
Numeric:.1.3.6.1.4.1.3375.2.2.6.4.2.3.1.4.10.111.110.101.99.111.110.110.101.99.116
HTH
/deb
