Michel_van_der_
Mar 21, 2006How do I configure fail over peer addreses and ConfigSync peer?
Subject says it all.
Do I need to create config file and load it up? And if so, what is the format
(can I find an example somewhere)?
Michel
- The failover addresses are not stored in the configuration file, but in the configuration database. Do a search for "Failover" in the "iControl v9.x" forum and there are a bunch of threads on what the database keys are and how to set them.
-Joe - Michel_van_der_
Thanks. As a follow-up question, how do I set the configuration
to be active/active or active/passive?
