junior_ra_16677
Aug 13, 2014How do I check if header does not exist ?
I know how to check if header exists, but how can I make the irule only check if header exists. If it doesnt I was going add something to the header
if { [HTTP::header exists "test"] } {
- Frank_Schuhmach
Altostratus
you can try something like this
if { [HTTP::header exists "test"] } { do something if header exists } else { if header doesnt exist, insert it HTTP::header insert test blahblah } - Mattias_Anderss
if { !([HTTP::header exists "test"]) } {
