xiaofan_lu_1135's avatar
xiaofan_lu_1135
Feb 08, 2010
How do I block ping for vs
When the pool member does not respond , how to refuse to ping, Irules can solve this problem? thanks
  • hoolio's avatar
    hoolio
    It isn't possible do disable ICMP to a virtual address with an iRule on a virtual server. You can check this post for details:
    vserver ALWAYS replies to ping
    http://devcentral.f5.com/Default.aspx?tabid=53&view=topic&postid=55930&ptarget=55932
    Aaron
  • Faced similar issue when migrating from GSS to GTM. Changed the monitor to TCP from ICMP and build iRule to drop requests if no active pool members are present.
  • Jason,
    I'm having a similar issue at this time but we are still using a GSS to monitor our F5 Virtuals. I can't figure how we can accurately monitor the health of the Virtual if it responds to Ping and TCP port are responsive. Any suggestions?
  • hoolio's avatar
    hoolio
    I assume you'd need to configure the GSS to check for a specific string in the response--not just that a TCP connection is completed. With the iRule you could send a reset in CLIENT_ACCEPTED if [active_members [LB::server pool]] == 0. The GSS health check should then fail when the VS's pool is down.
    Aaron
