JosephT's avatar
JosephT
Oct 23, 2008
Help write an irule to check and strip transfer-encoding header
We have a need to inspect all http requests and, if an HTTP request contains a Transfer-Encoding header with a value greater than 64 bytes, then we want to remove the Transfer-Encoding header from the HTTP request
I came up with this:
if { [HTTP::header exists "Transfer-Encoding"] && [HTTP::header "Transfer-Encoding"] > 64 } {
[HTTP::header remove Transfer-Encoding]
But it doesn't appear to be working correctly. When testing, if the HTTP request contains a Transfer-Encoding header (of any size), the HTTP request just never makes it through.
Any help would be greatly appreciated. TIA!
  • hoolio's avatar
    hoolio
    Hi there,
    If you add logging you could see in /var/log/ltm that [HTTP::header "Transfer-Encoding"] will return the value of the header. If you want to get the length of the header value you could use string length (Click here). Also, you should be getting a TCL error about an unknown command from this line:
    The square braces act like backticks in *nix, executing the code within. HTTP::header remove will return 0 or 1 depending on whether it runs successfully. So the braces would be executing 1 which isn't a valid command.
    This should work:
        if { [HTTP::header exists "Transfer-Encoding"] && [string length [HTTP::header "Transfer-Encoding"]] > 64 } {
    Aaron
  • Aaron. Your irule worked perfectly! Thanks for explaining the use of string length and the braces!!!
