Steve_Brown_882's avatar
Steve_Brown_882
Historic F5 Account
Sep 12, 2007
Help with Persit Irule
Hello All,
I have been working on rule that uses a unique x-forwarded-for header to persit traffic.
My orginal rule (below) works fine however when a customer hits the VIP that does not have the "X-Netli-Forwarded-For" header the traffic fails.
set xff_addr [HTTP::header "X-Netli-Forwarded-For"]
persist uie $xff_addr
So I created this irule (below) instead of the first one, however this seem to cause me to recieve 500 errors from my app server so I think it is breaking the request some how.
if { [HTTP::header exists "X-Netli-Forwarded-For"] } {
set persit_addr [HTTP::header "X-Netli-Forwarded-For"]
} else {set persit_addr [IP::client_addr]}
persist uie $persist_addr
Any Thoughts on this?
  • hoolio's avatar
    hoolio
    There is a typo in your rule with "persit". You should actually see a TCL error in /var/log/ltm stating the $persist_addr variable doesn't exist.
    With that updated, and a specified timeout, the rule should work as expected:
          set persist_addr [HTTP::header "X-Netli-Forwarded-For"]
      set persist_addr [IP::client_addr]
       persist uie $persist_addr 600
    You can view the current persistence records with the following command:
    watch -n1 'b persist show all'
    Each time the rule is triggered and there is an existing persistence record, you should see the age timer reset to 0.
    By default, on 9.2.4, it looks like (uie) persistence records are timed out after 180 seconds (without any type of persistence profile applied to the VIP). You or your app may expect persistence to be maintained for longer than the default time so you could explicitly specify the timeout.
    Aaron
