Help with L7 Irule with maintenance redirect when pool is down
I am very new to Irules and I am trying to create a L7 header redirection Irule with a maintenance page redirection if the particular pool is down. This should be possible, but I am having issues getting it to work.
Right now I have 2 Irules applied to the VIP and I want to combine them with different redirects based on the Pool.
Irule 1 Layer7 redirection when HTTP_REQUEST {
switch [string tolower [HTTP::host]] {
L7 Header Redirection
"productA.com" { pool productA-pool }
"productB.com" { pool productB-pool }
"productC.com" {pool productC-pool}
Irule 2 Maintenance redirection
set VSPool [LB::server pool]
if { [active_members $VSPool] < 1 } {
HTTP::redirect "http://www.maintenance.com"
This current setup works great if I want to send them to generic maintenance page. But now I'd like each pool to have their own maintenance redirect that more specific to the website. Example if productA-pool is down, redirect to productB-pool is down, redirect to etc.
I believe this can be done, but I can't seem to get my logic down in the Irule.
Any help with making this work would be appreciated.
thanks!
- Josiah_39459Historic F5 Account
Instead of setting the pool you check to be the default pool (set VSPool [LB::server pool]), set it to the be the pool based on host using the same logic you have for the pool command (can probably set the variable in the same switch even.
