supreme_86715
Jun 12, 2012help with iRules Regex scan statement.
I've been trying to scan the following URI inorder to extract specific fields. The URI is
/mapper/time_map/datatype/comtype/37.777125/-122.419644/13/1309/3164.json?v=1°ree_buffer=0.002&callback=jQuery1720814429080274308_1339544764657&_=1339544771741
i need a regex for a scan statement that will extract the data fields "comtype", "37.777125" and "-122.419644"
so far i've tried this, but keep getting "variable is not assigned by any conversion specifiers"
set testuri "/mapper/time_map/datatype/comtype/37.777125/-122.419644/13/1309/3164.json?v=1°ree_buffer=0.002&callback=jQuery1720814429080274308_1339544764657&_=1339544771741"
scan $testuri {%[^/]%[^/]%[^/]%[^/]%[^/]%[^?]} one two three four five six seven eight
any suggestions?
- MiLK_MaN
Why not just use split and then extract the field via lindex?
% set testuri "/mapper/time_map/datatype/comtype/37.777125/-122.419644/13/1309/3164.json?v=1°ree_buffer=0.002&callback=jQuery1720814429080274308_1339544764657&_=1339544771741"
% set split [split $testuri /]
{} mapper time_map datatype comtype 37.777125 -122.419644 13 1309 3164.json?v=1°ree_buffer=0.002&callback=jQuery1720814429080274308_1339544764657&_=1339544771741
% puts "[lrange $split 4 6]"
% puts "[lindex $split 4]"
comtype
The scan statement will still work, but it seem it has troubles with the / being the first character, so this will work:
% scan $testuri {/%*[^/]/%*[^/]/%*[^/]/%[^/]/%[^/]/%[^/]} one two three
3
% puts $one
comtype
% puts $two
37.777125
% puts $three
-122.419644 - hoolio
Nice work MiLK_MaN. I think the single scan command should be more efficient than split with lindex, etc.
Aaron - supreme_86715
Thank MiLK_MaN this works. Btw what editor/shell are you using the check test the irules? - MiLK_MaN
Just tclsh in a Mint Debian virtual machine on my home ESX server :)
