chuckcald_15879's avatar
chuckcald_15879
May 28, 2014
Help with Irule to redirect url port and pass POST data
Hi all.
Users must use https://sso.domain.com/sp/ACS.saml2 to pass their SSO (Single Sign ON) to our SP servers.
Our SP server listens on port 9031.
I need the SSO POST data coming to https://sso.domain.com/sp/ACS.saml2 to be redirected to https://sso.domain.com:9031/sp/ACS.saml2. Traffic to https://sso.domain.com:9031/sp/ACS.saml2 needs to sent to our "SSO" VIP.
The iRule have written doesn't pass the POST data through the redirect. Can anyone be so kind as to review my iRule?
    Check if request was a POST
   if { [string tolower [HTTP::method]] eq "post" } {
       Check if there is a Content-Length header
      if { [HTTP::header exists "Content-Length"] } {
         if { [HTTP::header "Content-Length"] > 1048000 }{
         Content-Length over 1Mb so collect 1Mb
            set content_length 1048000
         Content-Length under 1Mb so collect actual length
            set content_length [HTTP::header "Content-Length"]
      Response did not have Content-Length header, so use default of 1Mb
        Don't collect content if Content-Length header value was 0
       if { $content_length > 0 } {
          HTTP::collect $content_length
when HTTP_REQUEST_DATA {
if {[TCP::local_port] == 443 and [HTTP::uri] contains "/sp/ACS.saml2"}{
HTTP::redirect https://sso.domain.com:9031/sp/ACS.saml2
if {[TCP::local_port] == 9031 and [HTTP::uri] contains "/sp/ACS.saml2"}{
virtual SSO_9031
return
  • I need the SSO POST data coming to https://sso.domain.com/sp/ACS.saml2 to be redirected to https://sso.domain.com:9031/sp/ACS.saml2. Traffic to https://sso.domain.com:9031/sp/ACS.saml2 needs to sent to our "SSO" VIP.
    is sso.domain.com:443 virtual server? and what is its pool?
    is sso.domain.com:9031 also virtual server? is it same or different sso.domain.com:443 virtual server? and what is its pool?
    • chuckcald_15879's avatar
      chuckcald_15879
      sso.domain.com:443 is a virtual server with a pool named "pool_sso.domain.com_443" sso.domain.com:9031 is a different virtual server named sso_9031 with a pool named "pool_sso_9031"
      chuckcald_15879
      chuckcald_15879
      We do not want to route all traffic from sso.domain.com:443. Only traffic going to /sp/ACS.saml2. https://sso.domain.com goes to our sso.domain.com:443 virtual server and is needed for normal 443 traffic. https://sso.domain.com/sp/ACS.saml2 needs to be redirected to https://sso.domain.com:9031/sp/ACS.saml2 and sent to virtual server sso_9031 where the SP server is listening only on port 9031. I hope this clarifies more.
      chuckcald_15879
  • isn't it like this?
     config
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar443
    ltm virtual bar443 {
        destination 172.28.24.10:443
        ip-protocol tcp
        mask 255.255.255.255
        profiles {
            clientssl {
                context clientside
            http { }
            serverssl {
                context serverside
            tcp { }
        rules {
            qux
        source 0.0.0.0/0
        vs-index 36
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
    ltm rule qux {
      if { [HTTP::path] starts_with "/sp/ACS.saml2" } {
        virtual bar9031
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar9031
    ltm virtual bar9031 {
        destination 172.28.24.10:9031
        ip-protocol tcp
        pool foo
        profiles {
            clientssl {
                context clientside
            http { }
            tcp { }
        source 0.0.0.0/0
        source-address-translation {
            type automap
        vs-index 37
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm pool foo
    ltm pool foo {
        members {
            200.200.200.101:80 {
                address 200.200.200.101
     trace
    [root@ve11a:Active:In Sync] config  ssldump -Aed -nni 0.0 -k /config/ssl/ssl.key/default.key port 443 or port 9031 or port 80
    New TCP connection 1: 172.28.24.1(42244) <-> 172.28.24.10(443)
    1 1  1401289187.2551 (0.0347)  C>S SSLv2 compatible client hello
    1 2  1401289187.2552 (0.0000)  S>CV3.1(81)  Handshake
    1 3  1401289187.2552 (0.0000)  S>CV3.1(954)  Handshake
    1 4  1401289187.2552 (0.0000)  S>CV3.1(4)  Handshake
    1 5  1401289187.2598 (0.0045)  C>SV3.1(262)  Handshake
    1 6  1401289187.2598 (0.0000)  C>SV3.1(1)  ChangeCipherSpec
    1 7  1401289187.2598 (0.0000)  C>SV3.1(48)  Handshake
    1 8  1401289187.2672 (0.0074)  S>CV3.1(1)  ChangeCipherSpec
    1 9  1401289187.2672 (0.0000)  S>CV3.1(48)  Handshake
    1 10 1401289187.2696 (0.0024)  C>SV3.1(272)  application_data
        POST /sp/ACS.saml2 HTTP/1.1
        User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
        Host: 172.28.24.10
        Accept: */*
        Content-Length: 4
        Content-Type: application/x-www-form-urlencoded
        test---------------------------------------------------------------
    New TCP connection 2: 172.28.24.1(9736) <-> 172.28.24.10(9031)
    2 1  1401289187.2709 (0.0000)  C>SV3.3(109)  Handshake
    2 2  1401289187.2709 (0.0000)  S>CV3.3(81)  Handshake
    2 3  1401289187.2709 (0.0000)  S>CV3.3(954)  Handshake
    2 4  1401289187.2709 (0.0000)  S>CV3.3(4)  Handshake
    2 5  1401289187.2719 (0.0009)  C>SV3.3(262)  Handshake
    2 6  1401289187.2719 (0.0000)  C>SV3.3(1)  ChangeCipherSpec
    2 7  1401289187.2721 (0.0002)  C>SV3.3(80)  Handshake
    2 8  1401289187.2780 (0.0059)  S>CV3.3(1)  ChangeCipherSpec
    2 9  1401289187.2780 (0.0000)  S>CV3.3(80)  Handshake
    2 10 1401289187.2782 (0.0001)  C>SV3.3(288)  application_data
        Host: 172.28.24.10
        Accept: */*
        Content-Length: 4
    New TCP connection 3: 200.200.200.14(17839) <-> 200.200.200.101(80)
    1401289187.2790 (0.0006)  C>S
    Host: 172.28.24.10
    Accept: */*
    Content-Length: 4
      chuckcald_15879
      When I follow the configuration listed my browser connection gets reset and nothing loads. I noticed that your pool foo is listening on port 80. It should be listening on 9031. I made that change and the browser still get reset.
     config
        ip-protocol tcp
        profiles {
            clientssl {
                context clientside
            http { }
            serverssl {
                context serverside
            tcp { }
        rules {
            qux
        source 0.0.0.0/0
        vs-index 36
    ltm rule qux {
        virtual bar9031
        ip-protocol tcp
        pool foo
        profiles {
            clientssl {
                context clientside
            http { }
            tcp { }
        source 0.0.0.0/0
            type automap
        vs-index 37
    ltm pool foo {
        members {
     trace
        Host: 172.28.24.10
        Accept: */*
        Content-Length: 4
        Host: 172.28.24.10
        Accept: */*
        Content-Length: 4
    Host: 172.28.24.10
    Accept: */*
    Content-Length: 4
      chuckcald_15879
