kckirwan_49724
May 30, 2013Help with iRule to direct traffic to specific pool based on incoming port
I have a rule that is intended to redirect smtp traffic to specific pools based upon the port number for the incoming connection. All of the displays in that are logged to ltm log indicate that the ...
kckirwan_49724
Jun 13, 2013Thanks again for your help. The suggestions that you gave me, along with changing the default gateway of the pool member to point to the VIP we set up on the LoadBalancer ( not using SNAT for the VIP in question ) worked great!!!
Color this one done!
