kckirwan_49724
May 30, 2013Help with iRule to direct traffic to specific pool based on incoming port
I have a rule that is intended to redirect smtp traffic to specific pools based upon the port number for the incoming connection. All of the displays in that are logged to ltm log indicate that the ...
kckirwan_49724
May 31, 2013Kevin,
Thanks for you suggestions. I'll make those modifications and hope that it works.
Kevin
