ERLomboy_27803's avatar
ERLomboy_27803
Nov 06, 2014
Help with custom LB method
Hi F5 peers,
Need some help on how to approach a requirement from our DB team.
Customized LB which distributes traffic to pool_member 1 and pool-member2. If and when pool_member2 is unavailable traffic should go to pool_member1. But if pool_member1 is unavailable it SHOULD NOT go to pool_member2.
Thanks in advance!!
  • Hi,
        if { [active_members [pool_1] ] > 0 } {
            if { !([lsearch -exact [active_members -list pool_1] pool_member1:its_port]) } {
                reject
    • ERLomboy_27803's avatar
      ERLomboy_27803
      Hi Thomas, Thank you for sharing.. So it's only possible via iRule as you were suggesting?
  • Hi,
                reject
      ERLomboy_27803
  • This iRule will check if member1 is down. If it is, the request will be rejected. Then you also have to define priority group into your pool, with a higher priority for your member_2.
  • You could also do member-specific monitors applied to member_2. the first monitor would be the monitor used to check member_2, the second monitor could check the status of member_1 using monitor configuration items alias-address and alias-port settings that specify member_1
      ERLomboy_27803
      Hi Shaggy, Thanks for sharing.. Meaning I don't need to do the iRule, just monitoring? Edward
    • shaggy_121467's avatar
      shaggy_121467
      correct. member-specific monitors can be a pain as they are often forgotten when doing config changes or doing troubleshooting since most admins will only notice pool-level monitors
  • shaggy's avatar
    shaggy
      ERLomboy_27803
    • shaggy's avatar
      shaggy
