modyo_63245's avatar
modyo_63245
Nov 27, 2012
Help please with an LB&SSL configuration for a Rails APP
I need to set up an iRule with an SSL certificate which connects the 443 port to the 80 of the backend servers (the communication between the balancer and backends are in plain http). Problem is that my app is a Ruby on Rails app which needs to detect that the origin request was done in HTTPS to properly redirect and provide https urls.
The framework can read the following headers: (rails request.rb code snippet)
def scheme
if @env['HTTPS'] == 'on'
'https'
elsif @env['HTTP_X_FORWARDED_SSL'] == 'on'
'https'
elsif @env['HTTP_X_FORWARDED_SCHEME']
elsif @env['HTTP_X_FORWARDED_PROTO']
@env['HTTP_X_FORWARDED_PROTO'].split(',')[0]
else
@env["rack.url_scheme"]
end
end
How can i inject one of those headers? (ie: HTTP_X_FORWARDED_SCHEME=https) or should the iRule do this automatically for me when configuring certificates on it?
PS: Sorry about my iRule's technical level. I'm the developer behind the F5 balancer needing this simple header so my app can redirect properly to https urls :(
Thanks!
Antonio
  • It's unlikely you'd need to use an iRule to configure the SSL termination on the F5, normally a ClientSSL profile would be used. You can use an iRule like this to insert the header - note I've assumed the value should be 'on' not 'https' as you think but I could be wrong;
     [HTTP::Header] insert HTTP_X_FORWARDED_SSL "on"
  • Steve, i think it is "https".
    X-Forwarded-Proto Assistance
    https://devcentral.f5.com/community/group/asg/50/aft/26643/showtab/groupforums
  • Thanks Nitass. A HTTP profile didn't occur to me at all, but how do you insert the header with a value?
    For the rule, here's an update based on Nitass's information;
     [HTTP::header] remove "HTTP_X_FORWARDED_SSL"
     [HTTP::Header] insert HTTP_X_FORWARDED_SSL "https"
  • A HTTP profile didn't occur to me at all, but how do you insert the header with a value?is this what you are talking?
    e.g.
    [root@ve10:Active] config  b virtual bar list
    virtual bar {
       snat automap
       pool foo
       destination 172.28.19.79:443
       ip protocol 6
       profiles {
          clientssl {
             clientside
          myhttp {}
          tcp {}
    [root@ve10:Active] config  b pool foo list
    pool foo {
       members 200.200.200.101:80 {}
    [root@ve10:Active] config  b profile myhttp list
    profile http myhttp {
       defaults from http
       header insert "HTTP_X_FORWARDED_SSL: https"
    [root@ve10:Active] config  ssldump -Aed -nni 0.0 port 443 or port 80 -k /config/ssl/ssl.key/default.key
    New TCP connection 1: 172.28.19.251(35636) <-> 172.28.19.79(443)
    1 1  1354028315.6417 (0.0219)  C>S SSLv2 compatible client hello
    1 2  1354028315.6417 (0.0000)  S>CV3.1(81)  Handshake
    1 3  1354028315.6417 (0.0000)  S>CV3.1(953)  Handshake
    1 4  1354028315.6417 (0.0000)  S>CV3.1(4)  Handshake
    1 5  1354028315.6449 (0.0031)  C>SV3.1(262)  Handshake
    1 6  1354028315.6449 (0.0000)  C>SV3.1(1)  ChangeCipherSpec
    1 7  1354028315.6449 (0.0000)  C>SV3.1(36)  Handshake
    1 8  1354028315.6615 (0.0166)  S>CV3.1(1)  ChangeCipherSpec
    1 9  1354028315.6615 (0.0000)  S>CV3.1(36)  Handshake
    1 10 1354028315.6626 (0.0010)  C>SV3.1(175)  application_data
        HEAD / HTTP/1.1
        User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
        Host: 172.28.19.79
        Accept: */*
    New TCP connection 2: 200.200.200.10(35636) <-> 200.200.200.101(80)
    1354028315.6638 (0.0010)  C>S
    HEAD / HTTP/1.1
    Host: 172.28.19.79
    Accept: */*
  • Thanks Steve, Nitass. I'll try that header insertion on my iRule configuration.
