Mohamed_Lrhazi
Altocumulus
Mar 20, 2013Help improve http redirect iRule
I wrote this iRule so that my team could hopefully manage HTTP redirects easily, using a simple string data class with this format :
Host,URI,TARGET_URL,HTTP_CODE
Example:
www.example.com,/,http://target.site.com/path,302
*example.com,/foo/bar*,http://target.site.com/path/two,301
I need it to work on BigIP 10.0.
Any improvement suggestions highly appreciated.
https://gist.github.com/lrhazi/89b466ed2089cb19e6f9
Thanks a lot,
Mohamed.
- nitass
Employee
*example.com,/foo/bar*,http://target.site.com/path/two,301is it possible to not use wildcard on http host? if so, i think by modifying data group data a bit we will be able to use "class match" command instead of comparing one by one.[root@ve10:Active] config b class exact_class list class exact_class { "www.example.com/" { "http://target.site.com/path,302" } } [root@ve10:Active] config b class starts_with_class list class starts_with_class { "bha.example.com/foo/bar" { "http://target.site.com/path/two,301" } }
just my 2 cents - Mohamed_Lrhazi
Altocumulus
Yes, makes sense to sacrifice the wildcarding of hosts for performance. but in my version, I think 10.0, there does not seem to be a way to define a string data group as key and value, but just a list of strings....
Maybe there is a way though.. am thinking about it....
I added an improvement to the rule, where the 'taget" field is "eval"ed, so the user could put:*.example.com,/foo/bar*,http://target.site.com[HTTP::uri],301
and it would behave like http classes do.
