Help converting HTTPClass to Policy rule
I am trying to upgrade f5 ltm 10.2.4 to 11.5.3 and I get errors regarding existing httpclass, I am wondering if there is anyone that is expert who can help converting current httpclass config to a policy that serves the same purpose.
here is the configs on 10.2.4
profile httpclass ncast-com {
defaults from httpclass
pool ncast-cynweb-pool
redirect none
hosts {
regex "(?i)ncast.com"
"(?i)automotiveexchange.com"
"(?i)ncast.net"
"(?i)claim.com"
"(?i)collisionparts.com"
"(?i)billing.com"
"(?i)b-cms.com"
"(?i)b-csm.com"
profile httpclass gui-redirect {
pool none
redirect "/vehiclerepair"
hosts {
regex "(?i)ui-dev1.sinet.ehi.com"
"(?i)gui-dev2.sinet.ei.com"
"(?i)gui-dev3.sinet.ei.com"
"(?i)gui-dev4.sinet.ei.com"
"(?i)gui-dev5.sinet.ei.com"
paths "/"
- stan_piron
Cumulonimbus
the Policies are a set of rules. each rule replace a HTTP Class
so if both HTTP class are assigned on the same VS, you must create one policy with 2 rules:
- require http
actions : forwarding
Rule 1 :
- condition HTTP-Host host equals (List all URLs).
- Action forward pool ncast-cynweb-pool
Rule 2 :
conditions
- HTTP-Host host equals (List all URLs).
- path /
- Action http-reply redirect "/vehiclerepair"
conditions
the default options in condition is to ignore case, which is the same as (?i) in your URLs
Do not split URLs in multiple conditions, the OR operator is used between items of a condition, the AND operator is used between conditions.
