Guillaume_Bruss's avatar
Guillaume_Bruss
Jul 02, 2009
Help Access Sharepoint without ssl offloading
Unfortnatly our contractor does not understand how too configure Sharepoint server to allow SSL offloading.
So they install a certificate on the serveur
If I change my host to access direcltly to server (without BigIp)
It works well
If I configure to go through BigIp, when i try to connect, I have a warning about a "bad" certificate (I don't have this warning with direct access)
In The BigIp (v9 I think)
the virtual server is configured with
SSL Profile (Client) : clientssl
SSL Profile (Server) : serverssl
If anyone has an idea I will thanks him a lot
  • hoolio's avatar
    hoolio
    What exactly is the bad cert warning?
    If you have a valid cert on the MOSS you can convert it to PEM format, import it to the BIG-IP, configure a new client SSL profile and add that to the virtual server.
    Aaron
  • The "bad cert warning" is the IE 7 or IE 8 warning when you try to access a site with a self signed certificate
    this warning make looks like the site is not working for common users
    I will try to do convert to PEM and make network team import the PEM
    thanks
