N__197982's avatar
N__197982
Jan 17, 2018
Health monitor configuration help needed.
Folks, We are kind of struggling with some health monitor configuration on the F5. We need to query for a get command which will return the 200 HTTP code. However, this does not work.
The below command is being used for Send string: GET /jsp/Error.jsp HTTP/1.1\r\nHost: \r\nConnection: Close\r\n
We want to receive HTTP code 200
The "active member" returns the HTTP 200 correctly and show up, but the same happens with the "standby member" also shows up.
If I look at the Chrome debugging the "standby member" still returns code 200 due to a image getting loaded. This may be the issue.
However, if we query the nodes using CURL the "standby member" does give HTTP code 503.
Any suggestions for the resolution? How does the F5 actually query the members? How can I look at the code that are being return when the F5 queries the members?
Thanks!!! N.
  • To view the monitor log that is hitting your node: go into your pool > members > click on the node that is in the pool you want to check > There is a check box for Monitor Logging > check "Enable"
    The log file will be stored /var/log/monitors/
    If you just want to do an active/standby relationship for nodes, look into using priority groups on your pool.
