tkancianich_925
Nov 03, 2008Having issues converting 4.5 irule to v9.3
Not real familiar in creating or manipulating irules. Any assistance would be grateful & much appreciated ,thank you for taking a look!
Here is the rule I need to put on my v9.3 LTM:
if (http_uri contains ".nyk") {
redirect to "http://www2.nykline.com/redirect/SiteDown.html"
else if (http_uri contains ".nyks") {
else {
use pool pSidewinderNAT.80
- hoolio
This should be equivalent for 9.x:when HTTP_REQUEST { if {[HTTP::uri] contains ".nyk"}{ HTTP::redirect "http://www2.nykline.com/redirect/SiteDown.html" } elseif {http_uri contains ".nyks"}{ HTTP::redirect "http://www2.nykline.com/redirect/SiteDown.html" } else { pool pSidewinderNAT.80 } }
You could also replace the if/elseif/else with a switch command:when HTTP_REQUEST { switch -glob [HTTP::uri] { "*.nyk*" - "*.nyks*" { HTTP::redirect "http://www2.nykline.com/redirect/SiteDown.html" } default { pool pSidewinderNAT.80 } } }
Aaron - tkancianich_925
Thank you Aaron!
