Thiyagu_163984's avatar
Thiyagu_163984
May 21, 2017
Having issue while accesing LTM through Network managemet tools
Hi, I'm troubleshooting a strange issue on LTM. we are using HP Network Automatation tool for managing the LTM devices.
For some reasons Network management tools is unable to access the LTM and at the same time I'm finding the authentication error logs on LTM. I'm sure the username and password that the Network management tool used to communicate with LTM is correct.
LTM authentication error logs: ay 21 12:50:58 LB info sshd[3431]: Accepted keyboard-interactive/pam for opsware from 10.0.44.1 port 17401 ssh2
May 21 12:51:02 LB err sshd[3440]: error: PAM: Authentication failure for root from 10.0.44.1 May 21 12:51:02 LB info sshd[3443]: Connection closed by 10.0.44.1 May 21 12:51:02 LB err sshd[3501]: error: PAM: Authentication failure for from 10.0.44.1 May 21 12:51:02 LB info sshd[3504]: Connection closed by 10.0.44.1
May 21 12:51:03 LB err sshd[3506]: error: PAM: Authentication failure for from 10.0.44.1 May 21 12:51:03 LB info sshd[3509]: Connection closed by 10.0.44.1 May 21 12:51:04 LB err sshd[3511]: error: PAM: Authentication failure for from 10.0.44.1 May 21 12:51:04 LB info sshd[3514]: Connection closed by 10.0.44.1 May 21 12:51:04 LB err sshd[3518]: error: PAM: Authentication failure for from 10.0.44.1 May 21 12:51:04 LB info sshd[3521]: Connection closed by 10.0.44.1 May 21 12:51:05 LB err sshd[3523]: error: PAM: Authentication failure for from 10.0.44.1 May 21 12:51:05 LB info sshd[3526]: Connection closed by 10.0.44.1 May 21 12:51:06 LB err sshd[3528]: error: PAM: Authentication failure for from 10.0.44.1 May 21 12:51:06 LB info sshd[3531]: Connection closed by 10.0.44.1 May 21 12:51:06 LB err sshd[3534]: error: PAM: Authentication failure for from 10.0.44.1 May 21 12:51:06 LB info sshd[3537]: Connection closed by 10.0.44.1 May 21 12:51:07 LB err sshd[3539]: error: PAM: Authentication failure for from 10.0.44.1 May 21 12:51:07 LB info sshd[3542]: Connection closed by 10.0.44.1
Could you please guide me some steps to troubleshoot the issue?
Is there any troubleshooting commands to check the authentication issues on LTM?
Regards, Thiyagu
