jmetertea_34465's avatar
jmetertea_34465
8 years ago
handshake_failure errors during load test
I'm using BIG-IP 11.5.1 and using TLSv1.2.
I'm testing load on our servers using JMeter GUI,
When I submit from windows machine more than 150 threads using JMeter to specific domain I get handshake_failure errors as
javax.net.ssl.SSLHandshakeException: Received fatal alert: handshake_failure
and Connection reset:
java.net.SocketException: Connection reset
I can submit request using specific cipher suite(s), Is there a specific cipher suite(s) to send with the request that will prevent/reduce such errors? Is there a different configuration I should change/look into?
  • I can submit request using specific cipher suite(s), Is there a specific cipher suite(s) to send with the request that will prevent/reduce such errors?
    if i were you, i would try with a few hardware accelerated ciphers to see if there is any difference.
    K13213: SSL algorithms that are hardware accelerated (11.x - 12.x)
    https://support.f5.com/csp/article/K13213
    • jmetertea_34465's avatar
      jmetertea_34465
      We tried changing web acceleration profiles but still got same issue, is there a specific settings that can help?
    • nitass's avatar
      nitass
      how come it became web acceleration? i thought you were getting ssl handshake failure.
      jmetertea_34465
      My mistake, About the link you posted, my platform is Z100 not found in link, can you advice or which SSL algorithms is relevant to Z100 platform?
      jmetertea_34465
    • nitass_89166's avatar
      nitass_89166
      Icon for Noctilucent rankNoctilucent
      jmetertea_34465
