SSHSSH_97332
Jan 04, 2012HA Password Question
one colleague told me that there is a password that shouold match sothat Config sync work at Ha , is it root password or admin or what ?
- nitass
Employee
there is ConfigSync User setting at system > high availability > configsync. - SSHSSH_97332
Thanks - SSHSSH_97332
Document said: " The ConfigSync User setting allows you to specify the name of the user
who is allowed to perform configuration synchronization. In order for
configuration synchronization to function correctly, the name and password
for the ConfigSync User account must be the same on both BIG-IP units.
Whenever you change the ConfigSync User password, the BIG-IP system
reminds you to update the password on the peer unit."
Does thsi mean that this is the user account who will be only able to Sync Conf , other users ( even with admin privilidege ) will not be able to sync conf ? - nitass
Employee
Does thsi mean that this is the user account who will be only able to Sync Conf , other users ( even with admin privilidege ) will not be able to sync conf ?not really. it is just a user which bigip will use when doing configsync (to transfer ucs from/to peer unit).
