Fahad_130290's avatar
Fahad_130290
Dec 30, 2013
GTM To LTM connection disrupted
I get a following message on the LTM
LTM LOGS +++++++++ Dec 28 09:01:08 xxxxxxxxxx mcpd[1927]: 01070533:3: evWrite finished with no byte sent to connection 0xad1ccb0 (user %big3d) - connection deleted. Dec 28 09:01:08 xxxxxxxxxx mcpd[1927]: 01070533:3: evWrite finished with no byte sent to connection 0xacd2920 (user %big3d) - connection deleted. Dec 28 09:01:08 xxxxxxxxxx mcpd[1927]: 01070533:3: evWrite finished with no byte sent to connection 0xad78518 (user %big3d) - connection deleted.
After this I see that the GTM to LTM is reset. Anyone seen such behavior?
GTM LOGS ++++++++
Dec 28 09:01:08 xxxxxxxxxx gtmd[2070]: 011ae019:4: Closing idle connection to Dec 28 09:01:08 xxxxxxxxxx gtmd[2070]: 011a500c:1: SNMP_TRAP: Box state change green --> red (Box on Server QA BE BigIPs: Unavailable) Dec 28 09:01:10 xxxxxxxxxx gtmd[2070]: 011ae020:5: Connection in progress to Dec 28 09:01:10 xxxxxxxxxx gtmd[2070]: 011ae01c:5: Connection complete to . Starting SSL handshake Dec 28 09:01:10 xxxxxxxxxx gtmd[2070]: 011ae01a:5: SSL handshake complete to Dec 28 09:01:10 xxxxxxxxxx gtmd[2070]: 011a500b:1: SNMP_TRAP: Box state change red --> green
  • Routing instability?
    Try a long-term ping to check connectivity, use iqdump to capture iquery traffic.
  • Looks like network glitch. Check how many times connectivity is lost
    zgrep -i box gtm.*.gz
    Give traceroute from GTM to LTM. You can create a pool in GTM with as many hops in between GTM and LTM. Use ICMP gateway as monitor. from logs you will come to know which hop in between is having connectivity issue.
  • Thanks for the responses. In my case I have two GTM's at different location with two different network path polling the LTM.
