R__Neil_Fawcet1's avatar
R__Neil_Fawcet1
12 years ago
GTM - Data Center destinations in Topology Records and Topology Load Balancing at the Wide IP level
I am hearing that when doing Topology based Load Balancing at the Wide IP level, your topology records using Data Centers as the Destination will be ignored. In fact, this is what I'm seeing with my own eyes. Why would this be the only Destination type that does not work with Topology LB'ing at the Wide IP level? It would be so very useful. Am I missing something?
  • Hamish's avatar
    Hamish
    Nope. You're not missing anything. I discovered the same thing (After raising a ticket to ask why my topologies weren't working).
    It is documented however...
    Topologies
    H
  • I don't feel that this is clearly documented. It never says anything about using Datacenters at the "destination" being ignored, but that is exactly whats happens and it sounds like it confuses alot of people.
  • Hi,
    Just wondering if this is still relevant with 12.x versions?
