hidehara_189502's avatar
hidehara_189502
Mar 02, 2017
Get current connection on Ansible module : bigip_node
Hello all.
I'm trying to use bigip_node, bigip_facts module on ANSIBLE 2.2. I succeed to control a node to Forced offline (only active connections allowed).
After that, I want to check number of current connection the node, because of waiting for next work. How can I have the value of it?
I found a answer of Python iControl below. But I fail to find it on any ansible module.
Thanks for reading.
  • Hi Hidehara,
    You can use tmsh show sys connection command using raw module
    - name: "Get active connection on specific server"
      raw: "tmsh show sys connection ss-server-addr 192.168.1.12"
      delegate_to: localhost
    Syed Nazir
  • Hi Syed Nazir
    Thanks for great answer.
    I didn't imagine that accessing tmsh shell with raw module.
    I'll try to do that.
    Regards
  • Hi All,
    After an year , reopening thread , from the above query we will be able to find the no of connection when 0 need to disable , how to do that ?
    thanks in advance
  • I have struggled with this for sometime, I have not had success with the tmsh commands giving the proper output that will reflect 0 connections. Are there any modules that do this directly?
    ajayrah, did you ever find a working reliable solution?
