Geo Location I-Rule to Block Continents but allow certain IP addresses then redirect
I have a simple I-Rule that blocks Continents but I need to revise this to block continents I choose, but allow certain IP addresses from a Continent that is blocked. The Continents that are blocked will be redirected to a website. Any help will be appreciated. Here is my current rule blocking traffic from Europe
when CLIENT_ACCEPTED { Get the continent client IP if { [whereis [IP::client_addr] continent] eq "EU"} { log local0. "Traffic from Europe rejected." reject
- Richard__HarlanHistoric F5 Account
You can add a Datagroup with IPs that are allowed.
when CLIENT_ACCEPTED {if { ([whereis [IP::client_addr] continent] eq "EU") && not ( [class match [IP::client_addr] equals whitelist ) {reject}Have not tested just the idea should work.
- marv_Williams_5
Comes back as "Not well formed XML"
Sorry I missed a few close brackets this on syntax checked on a LTM and loaded without a problem
when CLIENT_ACCEPTED { if { ( [whereis [IP::client_addr] continent] eq "EU") && not ( [class match [IP::client_addr] equals whitelist] ) } { reject }}
- marv_Williams_5
This one worked. I just need to create a whitelist group. Thanks
- IRONMAN
Can i use this irule for my LTM to block source base continents wise block list, also how to LTM know the continents IP's .Let me know that step also.
