waqar_ali_17817
Apr 26, 2015gateway pool for loadbalancing connections between upstream routers
i have virtual server with gateway pool configured to load balance connection bewteen routers. what happens is when one of the router fails then some of the user connections are terminated. what should i do to ensure seamless operation if any of the router fails.
- nitass
Employee
you may check whether action on service down is useful.
sol15095: Overview of the Action On Service Down feature
https://support.f5.com/kb/en-us/solutions/public/15000/000/sol15095.html
