Muthu_108845's avatar
Muthu_108845
Dec 09, 2015
GATEWAY FAIL-SAFE CONFIGURATION WITH TWO PARTITION AND TWO ROUTE DOMAIN
I am looking for gateway failsafe example.
Here is my environment mode Active/standby
Partition two partition
route domain two route domain
Each domain having default gateway. Here is the configuration i Prepared, but it failed
bigpipe pool gateway_pool_unit1 {monitor all gateway_icmp member 10.75.64.1:0} bigpipe pool gateway_pool_unit2 {monitor all gateway_icmp member 10.75.0.1:0}
bigpipe pool gateway_pool_unit1 unit 1 bigpipe pool gateway_pool_unit2 unit 2
bigpipe pool gateway_pool_unit1 min up members 1 bigpipe pool gateway_pool_unit2 min up members 1
bigpipe pool gateway_pool_unit1 min up members failover bigpipe pool gateway_pool_unit2 min up members failover
bigpipe pool gateway_pool_unit1 min up members enable bigpipe pool gateway_pool_unit2 min up members enable
I need support correct this configuration
Regards Muthu
  • The first step of configuring the gateway fail-safe feature with route domains is to create two gateway pools in Common partition for each BIG-IP system in the device group.
    Run the commands on Active LB:
    # Go to Common Partition:
    cd /Common
    # Create the pools ( Members are the gateways of each route domains on the partitions):
    create ltm pool gateway_pool1 monitor gateway_icmp members add { 10.75.64.1%1:0 10.75.0.1%2:0 }
    create ltm pool gateway_pool2 monitor gateway_icmp members add {10.75.64.1%1:0 10.75.0.1%2:0 }
    # Assign the gateway pools to the corresponding units to which they are connected, since the pool information is synchronized between the systems:
    modify ltm pool gateway_pool1 gateway-failsafe-device unit1
    modify ltm pool gateway_pool2 gateway-failsafe-device unit2
    # The minimum number of gateway pool members that must be available to avoid the designated action:
    modify ltm pool gateway_pool1 min-up-members 2 min-up-members-action failover
    modify ltm pool gateway_pool2 min-up-members 2 min-up-members-action failover
     # Enable the member status checking:
    modify ltm pool gateway_pool1 min-up-members-checking enabled
    modify ltm pool gateway_pool2 min-up-members-checking enabled
    Save and sync the configuration to the standby device.
