JoeReid's avatar
JoeReid
Nov 06, 2019
frame check error
When I run the following "tcpdump -s0 -X -nnn -vvv -i (vlan interface)" , there is an output identifying frame check errors. It raises two questions.
1. Is this normal behaviour
2. Does it have an effect on the operability of the loadbalancer?
TIA
  • Lucern's avatar
    Lucern
    I'm guessing your devices are connected 1G or greater, correct?
    Make sure everything is set to Auto/Auto, long gone are the days where you need to hard set ports
    Check all cables involved - Swap em until you no longer get the errors
    If you're still getting errors swap SFPs
    If that doesn't work try another switch port, they DO go bad once in a while
    Not likely but possible bad port on the F5. Try another (might be hard to do without re-config though)
    My money is on one of the first three..
    And no, it's not normal and if you're getting a ton it can cause issues since you'll start getting a lot of retransmits..
    Good luck!
