Hamish's avatar
Hamish
Feb 06, 2014
Forwarding TCP RST on VS with loose-init?
OK. I think there's a change between 11.2.1 and 11.4.1 on forwarding of tcp resets for connections NOT in the connection table across a network VS...
Unfortunately, I don't have an 11.2.1 box handy to verify... But have discovered (After users reported issues following an upgrade from 11.2.1HF6 to 11.4.1HF2) that if a TCP connection is NOT in the connection table but the VS being uised has loose-init enabled, then the RST WILL NOT be forwarded to the destination. Any other packet will hit the loose-init and be forwarded, causing the connection table entry to be added once more. But if the connection goes idle, and the remote end RESETS the tcp connection without a FIN/FIN-ACK/ACK sequence (Which appears to be the method for closing an idle connection to Win2008 LDAP) then the client never gets the reset... And so is left with a hanging tcp connection...
Anyone else seen this? And does anyone know if this was the same behaviour in 11.2.1HF6?
H
  • i do not have 11.2.1 and 11.4.1 but it seems it (reset) is forwarded in 10.2.4 but 11.5.0.
    this is 10.2.4.
    root@ve10(Active)(tmos) show sys version|grep -A 6 Main\ Package
    Main Package
      Product  BIG-IP
      Version  10.2.4
      Build    817.0
      Edition  Hotfix HF7
      Date     Mon May 20 15:08:56 PDT 2013
    root@ve10(Active)(tmos) list ltm virtual fwd
    ltm virtual fwd {
        destination any:any
        ip-forward
        mask any
        profiles {
            fastl4_loose-init { }
        snat automap
        translate-address disabled
        translate-port disabled
    root@ve10(Active)(tmos) list ltm profile fastl4 fastl4_loose-init
    ltm profile fastl4 fastl4_loose-init {
        loose-initialization enabled
        reset-on-timeout disabled
    root@ve10(Active)(tmos) show sys connection cs-server-port 80
    Sys::Connections
    Total records returned: 0
    [root@ve10:Active] config  tcpdump -nni 0.0 -s0 port 80
    tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
    listening on 0.0, link-type EN10MB (Ethernet), capture size 65535 bytes
    23:03:59.752471 IP 200.200.200.101.1579 > 172.28.24.1.80: R 903943335:903943335(0) win 512 in slot1/tmm0 lis=
    23:03:59.752550 IP 172.28.24.15.1579 > 172.28.24.1.80: R 903943335:903943335(0) win 512 out slot1/tmm0 lis=fwd
  • and this is 11.5.0.
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show sys version
    Sys::Version
    Main Package
      Product  BIG-IP
      Version  11.5.0
      Build    0.0.221
      Edition  Final
      Date     Fri Jan 17 15:53:04 PST 2014
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual fwd
    ltm virtual fwd {
        destination any:0
        ip-forward
        mask any
        profiles {
        source 0.0.0.0/0
        source-address-translation {
            type automap
        vs-index 3
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm profile fastl4 fastl4_loose-init
        app-service none
    root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) show sys connection cs-server-port 80
    Sys::Connections
    [root@ve11a:Active:In Sync] log  tcpdump -nni 0.0 -s0 port 80
    07:24:32.651933 IP 200.200.200.101.2702 > 172.28.24.1.80: R 218255140:218255140(0) win 512 in slot1/tmm0 lis=
    07:24:33.651106 IP 200.200.200.101.2703 > 172.28.24.1.80: R 2115481654:2115481654(0) win 512 in slot1/tmm1 lis=
    07:24:34.653423 IP 200.200.200.101.2704 > 172.28.24.1.80: R 839077725:839077725(0) win 512 in slot1/tmm0 lis=
  • Hamish's avatar
    Hamish
    Yeah... I wonder if it changed in 11.3 or 11.4...
  • i think 11.3.
    [root@ve10:Active:Standalone] config  tmsh show sys version|grep -iA 6 main\ package
    Main Package
      Product  BIG-IP
      Version  11.3.0
      Build    3144.0
      Edition  Hotfix HF8
      Date     Thu Oct  3 18:22:28 PDT 2013
    [root@ve10:Active:Standalone] config  tcpdump -nni 0.0 -s0 port 80
    18:52:02.019072 IP 200.200.200.101.1126 > 172.28.24.1.80: R 989778309:989778309(0) win 512 in slot1/tmm0 lis=
    18:52:03.020870 IP 200.200.200.101.1127 > 172.28.24.1.80: R 1181986956:1181986956(0) win 512 in slot1/tmm0 lis=
    18:52:04.022056 IP 200.200.200.101.1128 > 172.28.24.1.80: R 692961061:692961061(0) win 512 in slot1/tmm0 lis=
