VB_95896's avatar
VB_95896
Apr 13, 2010
Forwarding HTTPS on Citrix Secure Gateway...
Hello,
I am trying to configure a BIG-IP ASM to handle HTTPS connexions between 1 Citrix client and 1 Citrix server (with "Secure Gateway" enabled). I doubt the Citrix server would allow the Big-IP to handle 2 HTTPS sessions : 1 on the client-side, 1 on the server-side (SSL does not allow a middle-man...). I am rather looking at a "VIP in transparent mode" solution where the HTTPS session would spread from the Citrix client to the Citrix Server (no decaps / encaps on the Big-IP).
Could you help me on this ?
NB : my Big-IP is currently in use for other servers (NAT mode).
Regards,
VB
  • Thanks for your answer, but :
    1 - SSL is required on the Citrix server
    2 - How do you implement your certificates ? Certif on the Big-IP = certif on the Citrix ?
    Regards,
    VB
